TC40D Parking brake
   / TC40D Parking brake #1
Wilkinsonlevi
Case DX40
I have a Case DX40 that is hydrostatic. I believe same as NH TC40DA?
If anyone has some photos of the parking brake assembly under neath they can share that would be awesome. I’ve looked online and cannot see what I need to see from the parts diagrams.
Thank you.
   / TC40D Parking brake #2
Not sure what you are looking for... need more info... but these are pics of our TC40D....
View attachment Brake Pedal Exploded View.pdf
Where does spring on right attach? Can you snap a photo?
Bracket with teeth on left that engages onto pedals. Is there a spring on that anywhere?
Thank you.
   / TC40D Parking brake #4
You can see where the spring attaches in the first photo.
Thank you very much for the info.
   / TC40D Parking brake #6
Also, I think the spring I circled applies spring tension to the rod which in turn keeps tension on the toothed bracket. It's that tension you feel when you pull up on the brake lever from above. Hold the lever and it engages when you hold the brakes down. Step on the brakes and that releases the lever and that same spring pulls the rod and bracket out of engagement.
   / TC40D Parking brake #7
Ford850... You are correct... besides the pedal tension springs that is the only spring for the Parking Brake assembly.... :thumbsup:
Glad this helped...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
2017 Ford F-550 Duralift DTAX39 39ft Insulated Bucket Truck (A55973)
2017 Ford F-550...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A55973)
John Deere 12in...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
