TC40D Parking brake
   / TC40D Parking brake #1
Wilkinsonlevi
Case DX40
I have a Case DX40 that is hydrostatic. I believe same as NH TC40DA?
If anyone has some photos of the parking brake assembly under neath they can share that would be awesome. I’ve looked online and cannot see what I need to see from the parts diagrams.
Thank you.
   / TC40D Parking brake #2
Not sure what you are looking for... need more info... but these are pics of our TC40D....
View attachment Brake Pedal Exploded View.pdf
Where does spring on right attach? Can you snap a photo?
Bracket with teeth on left that engages onto pedals. Is there a spring on that anywhere?
Thank you.
   / TC40D Parking brake #4
You can see where the spring attaches in the first photo.
Thank you very much for the info.
   / TC40D Parking brake #6
Also, I think the spring I circled applies spring tension to the rod which in turn keeps tension on the toothed bracket. It's that tension you feel when you pull up on the brake lever from above. Hold the lever and it engages when you hold the brakes down. Step on the brakes and that releases the lever and that same spring pulls the rod and bracket out of engagement.
   / TC40D Parking brake #7
Ford850... You are correct... besides the pedal tension springs that is the only spring for the Parking Brake assembly.... :thumbsup:
Glad this helped...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2004 STRICK S75 53' VAN TRAILER (A52708)
2004 STRICK S75...
