TC40D hydrostatic pedals no resistance
   / TC40D hydrostatic pedals no resistance #1
ConCon
123Tractor
Pedals completely went out on TC40D. There was no warning. Does anyone have a schematic on how this functions or ideas?
   / TC40D hydrostatic pedals no resistance #2
Welcome to the forum. It could be as simple as a linkage becoming disconnected. Take a peek under the footplate and see if anything is dangling. If you have a 'rocker' pedal you'd only feel the resistance of the centering spring. If you can reach up and work the pedal by hand you might be able to see what moves and what doesn't down below. (Model-specific help will be along shortly.)
   / TC40D hydrostatic pedals no resistance #3
Check out this thread on this common failure mode on these tractors. Hope this helps.
Thread 'Where the TC45D is NOT deluxe' Where the TC45D is NOT deluxe
Thank you - will be working on it this evening.
Thanks everyone. We had lost the #16 spring (per the schematic y’all shared with me). Thanks for the resources. We are up and running!
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
cummins generator (A56857)
cummins generator...
2000 Freightliner Discovery 36T 36ft. Class A Motorhome (A55853)
2000 Freightliner...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
