tc40a smoking
   / tc40a smoking #1
coyote homes
ASV RC 100
My Tc40a will only idle and produces alot of black smoke. i changed the fuel filter and that hasn't helped. do you think it is injectors or something simple. any help would be appreciated. thanks
   / tc40a smoking #2
Did you check the air filter? Black smoke is typically caused by the engine being over fueled or under aired.
Brian
   / tc40a smoking
i cleaned the air filter not long ago and the dust has been minimal but i will check that again. thanks
   / tc40a smoking #4
You could have a injector failure. That would allow the fuel to enter the cylinder all the time.
   / tc40a smoking #5
Pour some diesel conditioner in with new fuel and replace the fuel filter. You've already cleaned the air cleaner. I'm fairly sure it's not the pump. You've probably got some bad fuel or a piece of carbon/ dirt is not letting an injector valve close completely on it's seat. Black smoke is excess fuel versus air.
Sam
   / tc40a smoking #6
Pull your outer air filter and look at the inner filter. It's easy to get the inner filter reversed and block all air to the engine. The solid end should point outward and the hollow end toward the engine. Don't ask me how I know.:eek:
   / tc40a smoking #7
The underhood foam insulation pad on my TC45a came partially undone from the hood and was drooping down and sucking into the air inlet and did the same thing yours is doing. A little weatherstip adhesive cured the problem.
   / tc40a smoking #8
After you have made absolutely certain the air intake system is sound, check the fuel tank and be sure it has diesel fuel in it, not gasoline.
   / tc40a smoking #9
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2014 Ford E-350 16ft Box Truck (A51692)
2014 Ford E-350...
2012 JOHN DERE 310K BACKHOE (A51406)
2012 JOHN DERE...
