TC35DA Footwell Toolbox Does Not Fit TC35A
   / TC35DA Footwell Toolbox Does Not Fit TC35A #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
It does fit the contours just fine except for one thing, you can't go into high range. The shift bar hits the box never letting you select high range. Easy fix though. First pic shows narrowing the gap on the lower flat bar for the shift linkage.
Showing now where the shifter is located in high range.
Low range. You can guess where Mid range is. LOL
Encontered one other problem. The lower part of the shift bar now was hitting the back of the PTO safety switch. Easy fix. I popped it out and turn it around and. Wires are now on the opposite side by the shift bar.
Randy
Randy
Also added an extra nut and bolt to the box so it wouldn't rock around so much.
Randy
Randy
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
90018 (A48082)
90018 (A48082)
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2018 FORD F-150 (A50854)
2018 FORD F-150...
