TC35D steering won't lock
   / TC35D steering won't lock #1
LabLuvR
SC
Kubota MX5400
I know there has been some discussion on the steering lock problems with NH tractors. Mine will not lock and I intend to try and clean around the shock absorber. The problem is I don't know what to look for and what to lube one I get the two black panels off. Can someone tell me what I'm looking for and what to try and lube before I go out and buy a new part?
Thanks!
   / TC35D steering won't lock #2
Following this, loaned my TC35D to a friend and when he brought it back the steering wheel tilt lever was broke (pin was severed). NH says they don't offer a replacement?
   / TC35D steering won't lock #3
The strut is part # 86522914 and if you search amazon or ebay you will have a choice of prices and suppliers. Some members have had success with lubing the small protruding pin at the top of the strut. Tractorblue, you may only need a roll pin driven in where the other was severed. Most farm stores will have a selection if you can match to the broken one. Further info is available on TBN by searching the above part #.
Thanks guys, the shock absorber seems to be working fine. A guy at a NH dealer said the small block may be bad. I will try that for $35.
2022 New Holland C332 (A53317)
2022 New Holland...
2020 CATERPILLAR 299D3 SKID STEER (A52707)
2020 CATERPILLAR...
2018 Kawasaki Brute 800 ATV (A55853)
2018 Kawasaki...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
(4) 4" X 4" X 69" TUBING (A57192)
(4) 4" X 4" X 69"...
