TC35D steering won't lock
   / TC35D steering won't lock #1
LabLuvR
SC
Kubota MX5400
I know there has been some discussion on the steering lock problems with NH tractors. Mine will not lock and I intend to try and clean around the shock absorber. The problem is I don't know what to look for and what to lube one I get the two black panels off. Can someone tell me what I'm looking for and what to try and lube before I go out and buy a new part?
Thanks!
   / TC35D steering won't lock #2
Following this, loaned my TC35D to a friend and when he brought it back the steering wheel tilt lever was broke (pin was severed). NH says they don't offer a replacement?
   / TC35D steering won't lock #3
The strut is part # 86522914 and if you search amazon or ebay you will have a choice of prices and suppliers. Some members have had success with lubing the small protruding pin at the top of the strut. Tractorblue, you may only need a roll pin driven in where the other was severed. Most farm stores will have a selection if you can match to the broken one. Further info is available on TBN by searching the above part #.
Thanks guys, the shock absorber seems to be working fine. A guy at a NH dealer said the small block may be bad. I will try that for $35.
John Deere 7130 (A50120)
John Deere 7130...
28013 (A50322)
28013 (A50322)
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2008 John Deere 7330 (A50120)
2008 John Deere...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
43029 (A51691)
43029 (A51691)
