TC35D or TC40D
   / TC35D or TC40D #1
mark68
I am a boat dealer and need to "pull the trigger" today on either a TC35D or 40D. I am getting a FEL but by far will mainly be using the tractor for it's 3 point hitch and towing boats around the yard from 18' to 35' long. I will also use it for bush hoggin the yard. Can anyone tell me any main advantages or disadvantages between the 3 and 4 cylinders? Thanks
   / TC35D or TC40D #2
Go with the 4 cylinder 40 hp. More torque. The $$ difference isn't a whole lot considering the total price of the tractor.
Peter
   / TC35D or TC40D #3
Ditto, the price jump is worth it here even if you only really need the smaller machine.
   / TC35D or TC40D #4
</font><font color="blue" class="small">( Ditto, the price jump is worth it here even if you only really need the smaller machine. )</font>
Am I wrong? I thought the TC35 and the TC40 were the same size frame? The only real size difference is the hp?
   / TC35D or TC40D #5
</font><font color="blue" class="small">( Am I wrong? I thought the TC35 and the TC40 were the same size frame? The only real size difference is the hp? )</font>
Same size running gear except the 35 is 3-cyl and the 40 & 45 are 4-cyl. The overall weight, hydraulic lift, and loader specs (due to the higher hyd. pressure) for the 40 and 45 are a little higher than the 35, also.
   / TC35D or TC40D #6
Mark, I think the TC35D would be fine, but the 40 and 45 have about 300 lb higher lift weight on the FEL and 3PH. They also are a little heavier. I don't think you'd notice the difference pulling boats around your lot. With a large boat and heavy tongue weight, you may need to put some ballast in the loader bucket, but I think you'll be happy with any of the Class IIIs. /forums/images/graemlins/cool.gif
   / TC35D or TC40D #7
I have to agree with Jim as I don't think you need the extra HP on this call. Moving boats doesn't require it and a light brush hogging will work fine with a 35 HP machine. If you're looking for a write off then thats a different story. /forums/images/graemlins/crazy.gif
   / TC35D or TC40D #8
I would have to say go with the TC35. Unless you plan on using a lot of PTO dependent implements like a tiller, PHD, etc.. then you might want to go up to the 4 cyl. Otherwise I agree with PineRidge and jinman. Good luck! /forums/images/graemlins/smile.gif
   / TC35D or TC40D #9
It is, however, easier to go "Oooh oooh oooh oooh oooh oooh!" on a 40HP machine (ie Tim the Toolman)
   / TC35D or TC40D #10
That's true Laminarman. I had the same decision to make earlier this Spring but, if I was going to be doing what he's wanting the tractor for I would try and save a couple thousand and get the TC35. I'm just glad I'm not in his situtaion. It would be a tough decision to lay off the TC40. /forums/images/graemlins/smile.gif
2007 CHEVROLET SILVERADO K150 CREW CAB TRUCK (A51247)
2007 CHEVROLET...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
1261 (A50490)
1261 (A50490)
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
