TC35D or TC40D
   / TC35D or TC40D #1
mark68
I am a boat dealer and need to "pull the trigger" today on either a TC35D or 40D. I am getting a FEL but by far will mainly be using the tractor for it's 3 point hitch and towing boats around the yard from 18' to 35' long. I will also use it for bush hoggin the yard. Can anyone tell me any main advantages or disadvantages between the 3 and 4 cylinders? Thanks
   / TC35D or TC40D #2
Go with the 4 cylinder 40 hp. More torque. The $$ difference isn't a whole lot considering the total price of the tractor.
Peter
   / TC35D or TC40D #3
Ditto, the price jump is worth it here even if you only really need the smaller machine.
   / TC35D or TC40D #4
</font><font color="blue" class="small">( Ditto, the price jump is worth it here even if you only really need the smaller machine. )</font>
Am I wrong? I thought the TC35 and the TC40 were the same size frame? The only real size difference is the hp?
   / TC35D or TC40D #5
</font><font color="blue" class="small">( Am I wrong? I thought the TC35 and the TC40 were the same size frame? The only real size difference is the hp? )</font>
Same size running gear except the 35 is 3-cyl and the 40 & 45 are 4-cyl. The overall weight, hydraulic lift, and loader specs (due to the higher hyd. pressure) for the 40 and 45 are a little higher than the 35, also.
   / TC35D or TC40D #6
Mark, I think the TC35D would be fine, but the 40 and 45 have about 300 lb higher lift weight on the FEL and 3PH. They also are a little heavier. I don't think you'd notice the difference pulling boats around your lot. With a large boat and heavy tongue weight, you may need to put some ballast in the loader bucket, but I think you'll be happy with any of the Class IIIs. /forums/images/graemlins/cool.gif
   / TC35D or TC40D #7
I have to agree with Jim as I don't think you need the extra HP on this call. Moving boats doesn't require it and a light brush hogging will work fine with a 35 HP machine. If you're looking for a write off then thats a different story. /forums/images/graemlins/crazy.gif
   / TC35D or TC40D #8
I would have to say go with the TC35. Unless you plan on using a lot of PTO dependent implements like a tiller, PHD, etc.. then you might want to go up to the 4 cyl. Otherwise I agree with PineRidge and jinman. Good luck! /forums/images/graemlins/smile.gif
   / TC35D or TC40D #9
It is, however, easier to go "Oooh oooh oooh oooh oooh oooh!" on a 40HP machine (ie Tim the Toolman)
   / TC35D or TC40D #10
That's true Laminarman. I had the same decision to make earlier this Spring but, if I was going to be doing what he's wanting the tractor for I would try and save a couple thousand and get the TC35. I'm just glad I'm not in his situtaion. It would be a tough decision to lay off the TC40. /forums/images/graemlins/smile.gif
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Zerex 50/50 Anti-freeze (A53117)
Zerex 50/50...
20' BI-PARTING GATE (A51248)
20' BI-PARTING...
