TC35d or TC35da?
   / TC35d or TC35da? #1
35DMAN
St. Albans,VT
2007 TC40DA NH supersuite
I own a 2001 TC35d. It has been an excellent tractor but I am thinking of trading up to a newer one. Can anyone tell me if there are any notable differences between mine and a brand new one?
   / TC35d or TC35da? #3
Many people don't like the newer headlight styling.
   / TC35d or TC35da? #4
I don't like the new headlight design either, however, if getting a new tractor meant the new headlights I would do it in a heartbeat.
murph
   / TC35d or TC35da? #5
Wow! Nothing wrong with that old tractor? I bet your dealer loves you!;) I could see going to a TC40DA or TC45DA and maybe add a cab, but I'm surprised you would stick with the same model for only a newer model.
Okay...nuff said about my opinion. You didn't ask that, but only asked about notable differences.
1. Battery box improved
2. Instrument panel updated/changed
3. HST pedal return spring strengthened
4. Headlights...don't get me started.:rolleyes:
5. New loaders
6. Very expensive remote hydraulic valves (To be fair, this is the same on all tractors in the last few years.)
7. Grey seat instead of black one
8. New fender and hand-hold design
9. Improved joystick (stronger)
I'll probably think of more things, but these are the ones that come to mind quickly.
   / TC35d or TC35da? #6
5. New loaders
Didn't those new loaders include a significant upgrade in lift capacity? I know the Class II's were upped when they went to the "LA" style loader with teh curved boom.
John Mc
   / TC35d or TC35da? #7
34DMAN,
Although you may not want to here this I would have to agree with jinman. Why not get an Air Conditioned Cab & have the tractor re-painted so it looks like new. Now were talking a different machine. While your at it add a BH & your talking ALOT different machine. The only big plus you will get from a new 35DA is the quick attach loader.
Just my two Canadian cents.
John_Mc,
From the two specs I compared, (D vs. DA) lift capacity has changed 0 lbs. Unfortunately, in my manual, I do not have the lift capacity at 39" height & 19.7" forward of the pins. Even all the other specs such as max lift height & raise / lower, dump speeds are all identical.
Vic
   / TC35d or TC35da? #8
35DMAN:
Keep your old tractor and with the money you saved not "upgrading" you could buy more attachments :cool:. Jay
   / TC35d or TC35da? #9
I agree with the others on here. I would keep the tractor and either get implements, and or, maybe even put a cab on it. Unless you have a real high amount of hours I don't think you will gain a lot.
   / TC35d or TC35da? #10
John Mc
John, the Class IIIs have had the curved-arm loaders from the beginning and the specs for the new loader are almost identical as Vic noted. The main difference on the new loaders is some hydraulic line routing and the quick-attach buckets that were not available in 2001. My tractor is a 2001, and I had to add QA to the loader later.
The loaders for the Class IV TC55 and TC48 are slightly different in the way they attach to the tractor, but I don't believe there is a difference for the Class IIIs.
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
1989 21' Sun Ray Boat (A50515)
1989 21' Sun Ray...
KRONE KW5.50/4X7T HAY TEDDER (A51243)
KRONE KW5.50/4X7T...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
