TC35 front final drive teardown/inspection
   / TC35 front final drive teardown/inspection #12
I agree, my driveshaft cover made noise whether in 2wd or 4wd since it turns regardless. Glad you found your problem none the less.
I agree and I thought about that though when in 2WD it is turning because the wheels are turning it with no load/pressure. In 4WD it is turning because it is driven by the transmission and it has a load (tires) on it. Possibly something is worn in the connection points of the drive shaft allowing it to wobble/flex under pressure/force and rub on the tube??
I don't know, looking for input on this, maybe there is something with the driveshaft that is worn and needs attention?
Thanks for the comments.
~ Phil
~ Phil
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
Compressor (A55973)
Compressor (A55973)
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
