TC35 front final drive teardown/inspection
   / TC35 front final drive teardown/inspection #12
I agree, my driveshaft cover made noise whether in 2wd or 4wd since it turns regardless. Glad you found your problem none the less.
I agree and I thought about that though when in 2WD it is turning because the wheels are turning it with no load/pressure. In 4WD it is turning because it is driven by the transmission and it has a load (tires) on it. Possibly something is worn in the connection points of the drive shaft allowing it to wobble/flex under pressure/force and rub on the tube??
I don't know, looking for input on this, maybe there is something with the driveshaft that is worn and needs attention?
Thanks for the comments.
~ Phil
~ Phil
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2010 International 4300 Water Truck (A55973)
2010 International...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
19010 (A55851)
19010 (A55851)
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
