TC33DA stuck in full time 4WD
   / TC33DA stuck in full time 4WD #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
My New Holland TC33DA seems to be stuck in full time 4WD. I can't turn without the rear tires rubbing and skipping on the ground.
I checked the part-time/full-time 4WD lever/cable, and it's moving freely. It attaches to a small arm on the front underside of the tractor (with a spring inline) and that all looks OK.
I tried driving in a straight line, forward and backward, in all ranges, and that didn't cure it.
Any suggestions?
   / TC33DA stuck in full time 4WD #2
It sounds more like your differential lock is stuck.
I also wondered if it was the differential lock. So, as an experiment, I drove up to a stump alongside my gravel driveway, put the FEL bucket against it, and gently tried to move forward. Only one rear tire (and one front tire) spun in the gravel.
If it were a stuck diff-lock, wouldn't both rear tires spin?
   / TC33DA stuck in full time 4WD #4
   / TC33DA stuck in full time 4WD #5
Agreed, stuck in 4WD. I originally thought you meant both rears were spinning, and that's why one was skipping during turns.
   / TC33DA stuck in full time 4WD #6
adlertom
Did you ever get this problem resolved? My TC40DA supersteer is doing the same thing. It looks like the cable was hit by a branch or small log. I cant find anything on the parts diagrams.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A50397)
2022 Down2Earth...
2015 MACK CXU613 SLEEPER (A50505)
2015 MACK CXU613...
2015 Jeep Cherokee SUV (A48082)
2015 Jeep Cherokee...
2022 Club Car...
