TC33DA stuck in full time 4WD
   / TC33DA stuck in full time 4WD #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
My New Holland TC33DA seems to be stuck in full time 4WD. I can't turn without the rear tires rubbing and skipping on the ground.
I checked the part-time/full-time 4WD lever/cable, and it's moving freely. It attaches to a small arm on the front underside of the tractor (with a spring inline) and that all looks OK.
I tried driving in a straight line, forward and backward, in all ranges, and that didn't cure it.
Any suggestions?
   / TC33DA stuck in full time 4WD #2
It sounds more like your differential lock is stuck.
I also wondered if it was the differential lock. So, as an experiment, I drove up to a stump alongside my gravel driveway, put the FEL bucket against it, and gently tried to move forward. Only one rear tire (and one front tire) spun in the gravel.
If it were a stuck diff-lock, wouldn't both rear tires spin?
   / TC33DA stuck in full time 4WD #4
   / TC33DA stuck in full time 4WD #5
Agreed, stuck in 4WD. I originally thought you meant both rears were spinning, and that's why one was skipping during turns.
   / TC33DA stuck in full time 4WD #6
adlertom
Did you ever get this problem resolved? My TC40DA supersteer is doing the same thing. It looks like the cable was hit by a branch or small log. I cant find anything on the parts diagrams.
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
Cushman Cart (A55853)
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
