Loader Tc33da hydraulic noise
   / Tc33da hydraulic noise #1
Justin259
New holland Tc33da
I have a 2005 NH Tc33da that has recently started to make a loud whine when raising the loader and bucket curl up. I have checked fluid level and replaced the filter, not to sure where to look from here any help would be great thanks!
   / Tc33da hydraulic noise #2
Have you owed this tractor for a while? Are you in a cold region?
I have owned it about 5 years now, 700 hours on it now, iv always kept up on filter and fluid changes. Yes I am in a upstate NY but iv ran it year round the whole time iv had it and never ran into this
   / Tc33da hydraulic noise #4
Double check the shut/off for the hydraulics. On my tc33d, it was on the right side (under your right foot), on a gray block, where all the steel hyd pipes are coming out for the loader. Amongst the pipes, there is a place for a flat heat screwdriver. One way is off, the other way is on.
I did not know about that shut off I will check that first, i am getting a ton of vibration on the line coming from the cooler to the filter housing
   / Tc33da hydraulic noise #6
You can switch that while it is running too while you try the loader.
I could not find the shut off for the hydraulics, I did notice it is making the same noise when raising the 3point so I ended up taking the loader off to get a better view of the pump area
   / Tc33da hydraulic noise #9
What did you find out on this? Plugged or restricted line (bent, etc)?
I haven’t gotten it fixed yet, took the pump off and apart that all looks good going to start looking for a restriction somewhere
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
Ram Pickup Truck Bed (A49461)
Ram Pickup Truck...
