Loader Tc33da hydraulic noise
   / Tc33da hydraulic noise #1
Justin259
New holland Tc33da
I have a 2005 NH Tc33da that has recently started to make a loud whine when raising the loader and bucket curl up. I have checked fluid level and replaced the filter, not to sure where to look from here any help would be great thanks!
   / Tc33da hydraulic noise #2
Have you owed this tractor for a while? Are you in a cold region?
I have owned it about 5 years now, 700 hours on it now, iv always kept up on filter and fluid changes. Yes I am in a upstate NY but iv ran it year round the whole time iv had it and never ran into this
   / Tc33da hydraulic noise #4
Double check the shut/off for the hydraulics. On my tc33d, it was on the right side (under your right foot), on a gray block, where all the steel hyd pipes are coming out for the loader. Amongst the pipes, there is a place for a flat heat screwdriver. One way is off, the other way is on.
I did not know about that shut off I will check that first, i am getting a ton of vibration on the line coming from the cooler to the filter housing
   / Tc33da hydraulic noise #6
You can switch that while it is running too while you try the loader.
I could not find the shut off for the hydraulics, I did notice it is making the same noise when raising the 3point so I ended up taking the loader off to get a better view of the pump area
   / Tc33da hydraulic noise #9
What did you find out on this? Plugged or restricted line (bent, etc)?
I haven’t gotten it fixed yet, took the pump off and apart that all looks good going to start looking for a restriction somewhere
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
International 4700 Vibra Tiller (A51039)
International 4700...
