TC33D wont start, no lights. Main fuse where?
   / TC33D wont start, no lights. Main fuse where? #1
Anonymous Poster
Epic Contributor
I get nothing when i turn the key. Its not the stating fuse because i have a breaker in its place and i did replace with a fuse to be sure. I checked all fuses in the fuse box all good. Is there a main fuse and if so, where? Not the battery because is was running fine all day and i stopped just for a second and then it wouldnt start. Help!!!
The main fuse is on the other side of the tractor. Mine is attached, or very close to the starter. I think the owners manual shows it on the fire wall by the starter. Good luck..
   / TC33D wont start, no lights. Main fuse where? #3
One of your neutral safety switches may have also come out of adjustment which would not allow the starting circuit to complete the most common one to malfuntion is on the shift lever. The safety switch in the seat has also been known to cause some grief!
   / TC33D wont start, no lights. Main fuse where? #4
It was the main fuse. I found and replaced. Also first post since i got crashed on this forum and am starting over.
Mike
   / TC33D wont start, no lights. Main fuse where? #5
Mike
Hey Mike,
Where was the 'main fuse' located, as we have the same issue? No lights, etc.
   / TC33D wont start, no lights. Main fuse where? #6
See below:
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
2018 Nissan Sentra Sedan (A55758)
2018 Nissan Sentra...
Portable Restroom (A54865)
Portable Restroom...
