TC33D wont start, no lights. Main fuse where?
   / TC33D wont start, no lights. Main fuse where? #1
Anonymous Poster
Epic Contributor
I get nothing when i turn the key. Its not the stating fuse because i have a breaker in its place and i did replace with a fuse to be sure. I checked all fuses in the fuse box all good. Is there a main fuse and if so, where? Not the battery because is was running fine all day and i stopped just for a second and then it wouldnt start. Help!!!
The main fuse is on the other side of the tractor. Mine is attached, or very close to the starter. I think the owners manual shows it on the fire wall by the starter. Good luck..
   / TC33D wont start, no lights. Main fuse where? #3
One of your neutral safety switches may have also come out of adjustment which would not allow the starting circuit to complete the most common one to malfuntion is on the shift lever. The safety switch in the seat has also been known to cause some grief!
   / TC33D wont start, no lights. Main fuse where? #4
It was the main fuse. I found and replaced. Also first post since i got crashed on this forum and am starting over.
Mike
   / TC33D wont start, no lights. Main fuse where? #5
Mike
Hey Mike,
Where was the 'main fuse' located, as we have the same issue? No lights, etc.
   / TC33D wont start, no lights. Main fuse where? #6
See below:
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54757)
KNOW BEFORE YOU...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
