John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,819
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I was out working in the woods this afternoon and early evening in my TC33D (hydrostatic transmission). I thought I'd pull up a small stump in the middle of one of my trails, figuring it may have rotted enough to pop out by now.
I was working one of the lower tines of my forestry grapple under it and pushing and curling. I head a pop from under the tractor, and suddenly lost power to the wheels. I pressed the hydro pedal forward and backward, but nothing happened. It acted exactly as if I had in in neutral. I tried shifting in and out of both low and mid range. No luck. I still had hydraulics to the loader and 3 Pt hitch. I curled the loader back preparing to push myself back at least to the trail intersection behind me. I had moved back a couple of feet when I felt a shudder or vibration, and started getting power to the wheels again.
I was relieved, since I was on the far corner of the property and was not looking forward to figuring our how to get it back how again to where it could be reached by a service truck. I felt a few more shudders as I was getting turned around and headed home. It seemed to drive normally most of the way home, but I did think I felt that shudder again once or twice.
When I went to park it, I found that rather than the hydro pedal returning to neutral when I took my foot off of it, it was trying to creep forward at about walking speed. I moved the treadle to reverse and it backed up, but as soon as I removed my foot, it returned to rolling forward again.
Something is definitely not right, and I have a sinking feeling it's more than just a bit of crud or a stick jammed in the linkage. I have a belly pan which should be protecting things fairly well, but it was too dark out to really get a good look by the time I had a moment to try to examine things.
I'm going to remove the chains and attachments and clean things up tomorrow afternoon, then probably make a call to the dealer to see about getting things checked over.
Any thoughts on what might have happened? While I was using the loader with some force, I did not have the impression I was putting any unusual degree of load on the drive train.
