TC33D PTO Problem
   / TC33D PTO Problem #1
tc33brad
NE Ohio
2003 TC33D
I have a TC33D that the PTO had been jumping out of gear. I've read posts suggesting that the problem was a detent spring and ball that I tried but without any success. I talked to two dealers who stated it was the PTO gears and although that was not what I wanted to hear I bought the gears. Upon tear down of the rear end the two gears [number 10 and 19 on parts page 07F01 - PTO Gears] were trashed. It's a little over three hundred dollar repair for the gears. Hopefully this will be helpful to others who are having this problem.
   / TC33D PTO Problem #2
How difficult was the repair and did you need any special tools?
Any idea why the gears failed?
How many hours do you have on your tractor?
While I have not used my PTO much lately it has always worked fine in the past (knock on wood).
   / TC33D PTO Problem
No special tools are required and it's not a hard job but time consuming especially for someone who has never split a tractor apart. The use of my rototiller and not adjusting the slip clutch on the PTO shaft is what is being mentioned as the root cause. The tractor has I think around 550 hours.
2022 JOHN DEERE 5075E LOT IDENTIFIER 30 (A53084)
2022 JOHN DEERE...
DOOSAN DL300-3 HYD 4N1 COMBO BUCKET (A51247)
DOOSAN DL300-3 HYD...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
STORAGE FEES (A53426)
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
