TC33D Fuel in Crankcase
   / TC33D Fuel in Crankcase #1
3strucking
NH TC33D
I have a low hours NH TC33D that is leaking a lot of fuel in to the engine oil. Tractor starts and runs fine. There is no lift pump on the 843-N engine. I am guessing that there is a o-ring bad in the pump somewhere. Has anyone else had the same problem?
   / TC33D Fuel in Crankcase #2
I have not but if I'm remembering correctly it can occur when something (seal) has failed with the fuel pump. I'll see if I can find an old thread.
   / TC33D Fuel in Crankcase #3
This was the only one I could find doing a quick search:
   / TC33D Fuel in Crankcase #4
does it smoke on startup at all? could easily be a injector
   / TC33D Fuel in Crankcase #5
Tractor is heading for 20 years old. Send the pump and injectors out and get new o-rings and seals put in the pump and have the injectors tested and rebuilt if needed. The pump is the probable culprit.
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
Ryobi 10 Inch Table Saw (A57454)
Ryobi 10 Inch...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
2016 PETERBILT 579 SLEEPER (A59575)
2016 PETERBILT 579...
