TC33D Fuel in Crankcase
   / TC33D Fuel in Crankcase #1
3strucking
NH TC33D
I have a low hours NH TC33D that is leaking a lot of fuel in to the engine oil. Tractor starts and runs fine. There is no lift pump on the 843-N engine. I am guessing that there is a o-ring bad in the pump somewhere. Has anyone else had the same problem?
   / TC33D Fuel in Crankcase #2
I have not but if I'm remembering correctly it can occur when something (seal) has failed with the fuel pump. I'll see if I can find an old thread.
   / TC33D Fuel in Crankcase #3
This was the only one I could find doing a quick search:
   / TC33D Fuel in Crankcase #4
does it smoke on startup at all? could easily be a injector
   / TC33D Fuel in Crankcase #5
Tractor is heading for 20 years old. Send the pump and injectors out and get new o-rings and seals put in the pump and have the injectors tested and rebuilt if needed. The pump is the probable culprit.
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
378813 (A51573)
378813 (A51573)
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
NEW Fork Extensions (A53002)
NEW Fork...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
