John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,820
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
The fuel gauge on my TC33D stopped working. It shows empty when off, and full any time the power is on.
I've been having issues with the instrument cluster for some time - the fuel gauge would stick at empty when powered up. A smack on the the cluster would free it up and it would work normally. I suspect that is a mechanical problem: corrosion or something causing the needle to stick (the instrument cluster has always had a problem with condensation inside it).
This current problem seems different. Just from the behavior, I'm guessing it's either an electrical problem or the senesor in the tank is broken or jammed. We do have an issue with mice getting in to things around here, so maybe some wiring has been chewed up.
Does anyone have suggestions on what to start looking at first? Also, what is the easiest way to get to the wiring behind the gauges to check it out.
