TC33d Fan belt change??
   / TC33d Fan belt change?? #1
Bassdogs
Dale Hollow Ky
TC33D
The fan belt on my 33d jumped the pulley when a stick got stuck behind the fan shroud. The belt got tore up a before I realized the tractor was overheating. Can I replace the belt without removing the fan/shroud? What is the best procedure to change the belt?
And the fun gets better! Was trying to loosen the alternator to get the old [temp ok until I get the new one] back on the pulleys and bolt was frozen. Finally found that the bolt took a 14mm socket and applied a little extra umph and the bolt refused to budge but the front section of the alternator cracked I guess from where the ratchet pushed against the alum shell. Anyway now I'm ordering a new alternator and a belt. Got the alternator off by going in a few inches and removed the bolt that holds the adjusting bracket to the engine block. Its a pain but got it off and finally got the problem bolt loose by putting the whole thing in a shop vise. But its toast with a cracked shell. Guessing it will be fun to reinstall the new alternator since the work access it tight.
   / TC33d Fan belt change?? #3
Thanks for the post. I'm going to check mine this werkend.
Generac XG8000E Generator (A55973)
Generac XG8000E...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
