TC33d Fan belt change??
   / TC33d Fan belt change?? #1
Bassdogs
Dale Hollow Ky
TC33D
The fan belt on my 33d jumped the pulley when a stick got stuck behind the fan shroud. The belt got tore up a before I realized the tractor was overheating. Can I replace the belt without removing the fan/shroud? What is the best procedure to change the belt?
And the fun gets better! Was trying to loosen the alternator to get the old [temp ok until I get the new one] back on the pulleys and bolt was frozen. Finally found that the bolt took a 14mm socket and applied a little extra umph and the bolt refused to budge but the front section of the alternator cracked I guess from where the ratchet pushed against the alum shell. Anyway now I'm ordering a new alternator and a belt. Got the alternator off by going in a few inches and removed the bolt that holds the adjusting bracket to the engine block. Its a pain but got it off and finally got the problem bolt loose by putting the whole thing in a shop vise. But its toast with a cracked shell. Guessing it will be fun to reinstall the new alternator since the work access it tight.
   / TC33d Fan belt change?? #3
Thanks for the post. I'm going to check mine this werkend.
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
Informational Lot - Shipping (A52748)
Informational Lot...
2007 CHEVROLET BUCKET TRUCK (A52472)
2007 CHEVROLET...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
