TC33D Engine need a used one or rebuild
   / TC33D Engine need a used one or rebuild #1
holidayguy
Port Huron, Michigan
New Holland TC33D
Someone put gas in my TC33D, now it smokes and makes noises. Does any one know of a used engine or a place that can rebuild it?
   / TC33D Engine need a used one or rebuild #2
Have you cleaned tank, bleed lines, and exhausted all hope. If its running run it, a diesel engine that size is going to probably run $5k+. If you really truly destroyed yours beyond a professional rebuilt do an extensive Google search of your engine model, very good chance its used in towed air compressor, light tower, pump, or industrial generator. If it is, a used unit might be found at your semi local/regional equipment auction for a couple grand.
Thanks, i will look to see if i can find what else this engine was used in.
   / TC33D Engine need a used one or rebuild #4
Its a shibura 1.5L 3 cylinder, check for a model number ect on engine, it appear with a very quick search Shibura powers several pieces of equipment.
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
Year: 2004 Make: Kia Model: Optima Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2004 Make...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
