TC33D Engine need a used one or rebuild
   / TC33D Engine need a used one or rebuild #1
holidayguy
Port Huron, Michigan
New Holland TC33D
Someone put gas in my TC33D, now it smokes and makes noises. Does any one know of a used engine or a place that can rebuild it?
   / TC33D Engine need a used one or rebuild #2
Have you cleaned tank, bleed lines, and exhausted all hope. If its running run it, a diesel engine that size is going to probably run $5k+. If you really truly destroyed yours beyond a professional rebuilt do an extensive Google search of your engine model, very good chance its used in towed air compressor, light tower, pump, or industrial generator. If it is, a used unit might be found at your semi local/regional equipment auction for a couple grand.
Thanks, i will look to see if i can find what else this engine was used in.
   / TC33D Engine need a used one or rebuild #4
Its a shibura 1.5L 3 cylinder, check for a model number ect on engine, it appear with a very quick search Shibura powers several pieces of equipment.
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
