TC33D ELECTRICAL ISSUE
   / TC33D ELECTRICAL ISSUE #1
bigdawg1230
kingsport tn
tc33d
HELLO. I HAVE HAD A PROBLEM WITH MY HEADLIGHTS, WITH TRACTOR RUNNING AND WHEN I TURN ON HEADLAMPS THE TRACTOR WILL SHUT OFF AFTER A FEW MOMENTS. I HAVE CHECKED FUSES, AND ALL CONNECTIONS, ALSO BATTEY. ALL IS GOOD. I HAVE NOTICED A CHERPING NOISE COMING OUT OF ALTERNATOR WHEN I FIRST START, OR WHEN I TURN ON HEADLIGHTS. WITHOUT THE LIGHTS ON THE CHERPING WILL STOP. WITH LIGHTS ON IT MAKES CHERP, I WOUNDER IF THE ALTERNATOR HAS A BAD PART. AND IF IS CAUSING A SHORT WHEN RUNNING LIGHTS, THANKS FOR THE HELP,,, BIGDAWG 1230
   / TC33D ELECTRICAL ISSUE #2
can;t help directly.. but can make a general comment.
On older tractors, wher ethe headlamp power was sourced off the same wireing as the ignition, sometimes you could get a situation where the laod was too much for the wire.. thus it dropped voltage and the ignition dropped out with lamps on.
your machine don't have points.. but does have a fuel shutoff solenoid i'm betting.
   / TC33D ELECTRICAL ISSUE #3
If you are getting a chirping noise from the alternator, it could be a loose belt. If the belt is loose, the alternator will be slipping and not rotating fast enough to put out the ampereage that is needed.
   / TC33D ELECTRICAL ISSUE #4
After checking the belt, check the battery cables and connections. You might be getting some voltage drop somewhere too.
   / TC33D ELECTRICAL ISSUE #5
deffinately getting voltage drop... ;)
ok thanks, will check it out Saturday, I realy do appreciate all of the help,
bigdawg1230
   / TC33D ELECTRICAL ISSUE #7
let us know what you find!
2013 GENIE GTH-5519 TELEHANDLER (INOPERABLE) (A58216)
2013 GENIE...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2002 Caterpillar 307C Midi Excavator (A56857)
2002 Caterpillar...
2021 P&J 40' GOOSENECK TRAILER (A52708)
2021 P&J 40'...
LOT: Landscape Timbers, Hand Tools (A59076)
LOT: Landscape...
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
