TC33d, Can i put a 40hp engine onto a 33hp
   / TC33d, Can i put a 40hp engine onto a 33hp #1
bobs1970camaro
1999 New Holland TC33D
I have a 1999 new holland tc33d, engine code 58129 can i bolt a 40 hp diesel up to the 33 hp ??? Because the 30 hp block is cracked ??? Unless someone out there has a diesel engine for sale ??? Thanks bob a !!!
   / TC33d, Can i put a 40hp engine onto a 33hp #2
If you could do that, your next cracks might be in the transmission or differential or PTO. It does not make sense to put a larger HP and higher torque engine into a drivetrain designed for 33 hp. If you can get the engine to fit and detune it to produce lower hp & torque, then you might be okay.
   / TC33d, Can i put a 40hp engine onto a 33hp #3
Bobs1999NewHollandTC33d.....
Where is the block cracked? Any pictures? What makes you think the block is cracked?
   / TC33d, Can i put a 40hp engine onto a 33hp #4
Not sure on that model but many have the same motor in varying hp ratings. I wouldn't worry about the power increase hurting much if its an hst. The HST relief valve protects somewhat, might check to make sure the pto components are shared with the 40 hp model.
The block is cracked accross the back, going to take engine out tommorrow and check crank. the block looks like it can be welded.
   / TC33d, Can i put a 40hp engine onto a 33hp #6
If the crack doesn't extend into any oil passages, I don't see why not. Vee out the crack, warm block to around 400 degrees F. Then use Ni-rod to weld. Best done by a professional welder.
Will a N843 engine out of a skidsteer fit into a 1999 New Holland TC33D, engine# 58129, ???
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
TEST BID LOT (A50775)
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
John Deere 772-A Grader (A52384)
John Deere 772-A...
