TC33D Auxiliary Lighting
/ TC33D Auxiliary Lighting #1
Spencer
Western Michigan
NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
Here are a few pics of my two new auxilary lights that I mounted on my TC33D. I tapped into the existing wiring harness that is specifically for rear work lights. I used brackets right from NH that are specifically made for these auxilary lights. You just unbolt the rear flasher lights and place the bracket between the rear flasher bracket and the ROPS. The brackets were about 16 bucks a piece from my dealer. The lights are from J.W. Speaker Corporation and sold as Speaker agri-brite. They both are 4" x 6", 12 Volt, 4 Amp halogen flood lights. They have a watertight switch built right into them. They were 26 bucks a piece from my dealer. The wiring harness that NH provides is on a 15 amp fuse. I didn't blow that fuse, but the first time I went to start up the tractor after the installation I forgot to turn off all my lights. I had on both auxilary lights, the front headlights, and the rear tail lights. After the glow plugs turned off I went to turn the switch further to engage the starter and thats when my main 30 amp fuse blew. I now have some spares in the toolbox on the tractor. I will always make sure all lights are off when starting the tractor from now on.
First picture is a full view showing both lights.
Spence
This is a view of the rearward facing light.
Here is the view of the back side of the forward facing light.
Here is a side view of the forward facing light
Here is the wiring harness that I used for power.
/ TC33D Auxiliary Lighting #6
Does the light swing to the right so you can still fold the ROPS?
Yes it will swivel to the side if you leave the mounting nut loose enough but it will still get hit by the rops if you fold it. I read on an earlier post about someone with the same situation. Their solution was to put the pin back in the upper section of the rops as I have shown in this attached image.
Spence
/ TC33D Auxiliary Lighting #8
Nice lighting setup for night time use.
The driveway looks like it would be fun to plow under any amount of snow /w3tcompact/icons/smile.gif and you have 3 if not 4 times more snow than I. /w3tcompact/icons/eyes.gif
Thanks Thomas,
During the week nightime is the only time I can use the tractor. I pretty much have the winters off but my wife works days so I stay home and take care of our beautiful 16 month old girl. We didn't have any snow on the ground here for weeks until last friday night. It is still snowing now, I think we have 10 or 12 inches now.
Spence
/ TC33D Auxiliary Lighting #10
Spencer,
Who is your NH dealer? Nice lights /w3tcompact/icons/tongue.gif
Nick
I shopped at both Grandville Tractor and Burnips Equipment. I ended up buying at Burnips because they are bigger. They service more, they stock more, and they have more implements in stock. Both places were pretty close on prices and each was willing to match the other to get the deal. I don't think I've gotten any great deals on attachments and such after the initial sale. I am going to have to start shopping around more from now on.
Spence
/ TC33D Auxiliary Lighting #12
Spencer,
I bought my 40d at Burnips too (dealt with Scott), Looked at Grandville, but felt like I was going to pay too much. I've never bought any implements from Burnips, you might want to check out Wobma's in Wayland. I know that's kind of a hike for you, but I think I've gotten some great deals there.
I live in Caledonia, so it's not too far from me. E-mail me off-line and I'll tell you more.
Nick
/ TC33D Auxiliary Lighting #13
nice job, you gave me some good ideas. we are still in the leaf season here in pa and with all the rain we are getting the days are very short ... so lights all over the place are now a must.
thanks for your impute.
I was outside last night mulching up leaves on my paths through the woods with my Bush Hog. The lights were very nice to have. I do wish I had some up higher, like on the underside of the top of the ROPS.
/ TC33D Auxiliary Lighting #15
Hi Spencer and all.
<font color=blue> I do wish I had some up higher, like on the underside of the top of the ROPS. </font color=blue>
I will take that as an endorsment that when I put lights on my tractor I should mount them as high as possible!
Thanks for sharing that insight!
Bill in Pgh, PA
/ TC33D Auxiliary Lighting #16
you got me going by the way those pictures looked ... so i treated myself at my local auto parts place to two square tractor lights with a protective wire shield included. my ROPS have a roof attached to it (power trac 425). so i started to mount them in the corners of the combination roof/ROPS area.
these tractor lights can come in different types of beams. i will do a follow up on make, model and the various beams.
/ TC33D Auxiliary Lighting #17
Spencer,
Nice job on the lighting additions, but my question is directed toward the wiring harness. When
I asked my NH dealer for the 2 pole connector that mates to the factory supplied plug (the one you used for the new lights), they had no idea what I was asking about. I took one of the parts guys to the showroom when they could not identify the plug in the parts book or harness diagram. They were surprised that it was there. I have yet to find a 2 pole plug to fit. I finally did find a 2 pole plug at Tractor Supply (second store I visited), but it did not have the right prong depth. I have since been using the same setup you show.
Anybody out there know anything about this NH supplied 2 pole plug?
/ TC33D Auxiliary Lighting #18
I looked around for the plug and didn't find one. I ended cutting the plug off and using my own connectors.
/ TC33D Auxiliary Lighting #19
You might check with Radio Shack, I've had good luck finding odds and ends for most electrical jobs.
/ TC33D Auxiliary Lighting #20
I got a couple of them at an Advance auto parts store; they were with the trailer wiring. I had a hard time finding them also.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
Massey Ferguson 9250 (A63688)
Massey Ferguson...
Bobcat MT85 (A60462)
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
