TC33D 7308 Hydraulic fitting leak
   / TC33D 7308 Hydraulic fitting leak #1
shade2u2
Ohio
NH TC33D
One of the 4 fittings that connect to the FEL is leaking all at once. It was tighter than normal when disconnecting. It is a steady fast drip.
What might it be?
   / TC33D 7308 Hydraulic fitting leak #2
Is it leaking after you disconnected it? Probably a bad o-ring inside and the connector needs to be replaced.
The previous owner of my TC29D replaced all the quick connects with these flat style which are much easier to clean before I reconnect them. I give them a quick shot of brake cleaning spray to get all the dirt off.
It leaks while connected - not after being disconnected.
   / TC33D 7308 Hydraulic fitting leak #4
It is still probably a bad O-Ring.
Did you have it disconnected recently?
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Michigan L90 (A55272)
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
