TC33D 7308 Hydraulic fitting leak
   / TC33D 7308 Hydraulic fitting leak #1
shade2u2
Ohio
NH TC33D
One of the 4 fittings that connect to the FEL is leaking all at once. It was tighter than normal when disconnecting. It is a steady fast drip.
What might it be?
   / TC33D 7308 Hydraulic fitting leak #2
Is it leaking after you disconnected it? Probably a bad o-ring inside and the connector needs to be replaced.
The previous owner of my TC29D replaced all the quick connects with these flat style which are much easier to clean before I reconnect them. I give them a quick shot of brake cleaning spray to get all the dirt off.
It leaks while connected - not after being disconnected.
   / TC33D 7308 Hydraulic fitting leak #4
It is still probably a bad O-Ring.
Did you have it disconnected recently?
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
FAKE (A52472)
FAKE (A52472)
