TC33 Ignition Switch Problem
/ TC33 Ignition Switch Problem #1
chipaz
I know there has been a lot of discussion about this and similar issues and now I guess I get to add my two cents worth. The tractor is a 2003 TC33D model with about 40 hours on it. I have already been through the 10-amp fuse popping issue and resolved the problem by installing a 10-amp relay fuse in its place. This weekend at a most inconvenient time and location, the tractor started to run a little funny and thanks to that darn seat safety switch, it would not start after I dismounted and climbed back into the cockpit. The tractor behaved as if there was either no power (no indicator lights) or it would start and then shutdown after I released the key. Finally, after playing around with the ignition switch, I discovered if I held the key half way between the start and run position, I could keep the tractor running long enough to get back to the garage and park it. I will visit the dealer this week and a follow-up with status will be posted.
/ TC33 Ignition Switch Problem #2
NH must be buying them lucas parts again!
Soundguy
/ TC33 Ignition Switch Problem #3
I too was having switch problems. Dealer replaced it once but it still acted up. I don't know if this was mentioned here before but try removing the rubber from around the key. I have not had a problem since doing so.
/ TC33 Ignition Switch Problem #4
<font color="blue"> NH must be buying them lucas parts again! </font>
Ah, Lucas, The Prince of Darkness. Got to know him well working on my wife's MGB. /forums/images/graemlins/tongue.gif
Well, it was definitely a defective switch in this case. I experimented with a key I had that did not have the protective rubber boot around it and there was no difference in the behavior of the switch's operation. I installed the replacement switch in about 10 minutes and it worked like a champ. I re-installed the original switch just as a test and it was definitely bad. The tractor is still under warranty and the dealer reimbursed me the $44.10 for cost of the replacement switch when I returned the defective part.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2013 Tahoe Q4 Boat with 2013Tracker 18ft S/A Boat Trailer (A59231)
2013 Tahoe Q4 Boat...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
