TC30 Glow Plug Light
   / TC30 Glow Plug Light #1
RRRPBR
TC30
2005 TC30
When cold I can’t get the glow plug light to come on. After the engine warms I am able to turn engine off and get light to appear when restarting. Any ideas?
   / TC30 Glow Plug Light #2
TC29D, had no glow plug light, it was the relay...
   / TC30 Glow Plug Light #3
Let me know if you figure this out. I've got an '01 TC30 and the glow plug light isn't reliable - sometimes bright as ever, other times so dim I have to shield it from shop lights to see it.
   / TC30 Glow Plug Light #5
Dont just throw parts at a machine. The glow plug circuit isnt very complex. It does use a heavy gauge wire from the key switch and I found mine fairly burnt.
My light is also intermittent but just because the light isnt lit dosnt mean the glow plugs arnt working. Use a test light or multi meter. My bulb socket was actualy not making great contact.
   / TC30 Glow Plug Light #6
On my TC30 the glow plug light almost never works, but the glow plugs always do when I turn the key backwards.
   / TC30 Glow Plug Light #7
Funny thing, Glow plug light on my TC33da started acting up the other day. First checked the ignition switch. Opened it up and found no fault, regreased it with dielectric grease. Then checked the connections with the relay. I could get it to light intermittently wiggling the connector. It didn't look burnt, but I loaded it with grease and wiggled a bit and it seems to work solidly again. Time will tell, but That would be my first check.
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
2025 JOHN DEERE XUV 825M S4 UTV (A57192)
2025 JOHN DEERE...
