TC30 Diff Lock, Locked ?
   / TC30 Diff Lock, Locked ? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I was cleaning up a muddy mess on the adjacent lot next to my house and had to use the differential lock to get enough traction to drag the loader bucket in reverse to do some rough grading. After I drove back to my lot and made several turns, starts and stops, I realized that the diff lock pedal never returned to the upright position and I was tearing up my lawn /forums/images/graemlins/blush.gif
Went back and forth and kept kicking the foot lever to release the lock. Finally had to reach down and pull up with my hand to finally get the diff lock released. What gives ?
   / TC30 Diff Lock, Locked ? #2
Something is not right. Mine either comes back on it's own shortly after releasing the pedal or certainly releases with a tap of one or the other brake pedals.
   / TC30 Diff Lock, Locked ? #3
lubricate the shaft where it goes into the housing this should end your problem
   / TC30 Diff Lock, Locked ? #4
Jerry,
Mine pops right back up as soon as I release my heel as it says in the manual. They do talk about the lock failing to disengage, but your issue sounds more like lubrication as spencer suggests.
By the way, could I get you to measure the outside diameter of your pto cover threads, someone ran over mine (no names please!) and I think that guy would be better off with a pipe nipple & cap if they are pipe threads!
Thanks,
Don
   / TC30 Diff Lock, Locked ? #5
There is a procedure in the manual that describes what to do if the differential lock won't release. It has to do something with driving slowly and tapping the individual right or left brake. Check your manual - I don't have mine at home to look it up and give you an exact quote.
   / TC30 Diff Lock, Locked ? #6
If a TC30 has the same PTO cover as a TC35D, its not pipe thread. Its a bit over 2" pipe and appears to be a straight thread not a taper like on pipe fittings. They are pretty cheap though...I've already bought 1 !!! /forums/images/graemlins/tongue.gif
Ok, my threads on the cap (outside threads) are 2 5/8
I'll sell you my cap for $1,000,000 /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/laugh.gif
   / TC30 Diff Lock, Locked ? #8
Jerry,
Appreciate your help, but I'll have to pass on the sales offer. With your prices if I continue at the rate I am going (1 cap for the first 2 months of ownership) I'll be broke in about two years! /forums/images/graemlins/grin.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
Thanks again!
Don
   / TC30 Diff Lock, Locked ? #9
I have a Ford 1910 and the dff. lock would not disengage. I had to open the differential case from the top (under the seat castiing 3 point lift arms that rotate) and free it up /forums/images/graemlins/smirk.gif Nothing was broke, just tight. A local dealer had the same experience. I got a gasket before hand and it was a 3-4 hour job. If I had to do it over I'd get a gasket for the transmission (regular gear) cover so I could have more thoroughly cleaned-up the metal shavings /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( If I had to do it over I'd get a gasket for the transmission (regular gear) cover so I could have more thoroughly cleaned-up the metal shavings
)</font>
/forums/images/graemlins/blush.gif /forums/images/graemlins/confused.gif You should never say 'transmission' and 'metal shavings' in the same sentence /forums/images/graemlins/crazy.gif
PALLET OF NO-TILL COULTERS, JOHN DEERE UNIT MTD (A52708)
PALLET OF NO-TILL...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
