TC29 shifting
   / TC29 shifting #1
Anonymous Poster
Epic Contributor
Hello. About a month ago I bought a TC29 (manual shifting). When changing gears or changing ranges I almost always grind the gears, sometimes worse than others. This even happens when beginning from a complete stop. Can anyone offer any advice on changing gears/ranges on the TC29 without the grinding effect?
Thanx
Vernon Bush
   / TC29 shifting #2
If you're fully depressing the clutch pedal a couple of seconds before moving the shift lever, and you're still getting the grinding, it sounds as if you need a clutch adjustment.
Bird
   / TC29 shifting #3
Bird, that was my thought as well. To tell the truth, when I bought my TC29D, I didn't really look at the manuel trans. Could there be some type of linkage or springs that might cause a problem?
Ernie
   / TC29 shifting
You may want to check your owner's manual or with your dealer, I don't think the transmission is a syncronized transmission. If it is not, you will get the grinding your talking about (unfortunaetly) If it is a syncro transmission, the gears do continue to spin for a few seconds after the clutch is depressed especially at higher rpms.
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
County Line 5' Poly Feed Trough (A50515)
County Line 5'...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
