TC29 in a pasture rehab.
   / TC29 in a pasture rehab.
When I checked the oil, it is a bit milky not terribly milky but slightly, so I am going to do a oil change before I try anything else.
Changed the hydraulic fluid, and yeah didn't change since its not hydraulically driven (As far as I can tell)...so next is a trip to the tractor doctor...am sure it will be a clutch replacement. They quoted me $1,500 and that seems in line with other quotes that I have seen online from others...
   / TC29 in a pasture rehab. #23
Did you get the instrument panel going? I'm sure a new panel would be pretty costly?
   / TC29 in a pasture rehab. #24
Have you tried adjusting the clutch? What is the freeplay currently? The manual says about 1in at the pedal. You should also have a spring holding the pedal up.
   / TC29 in a pasture rehab. #25
Anything new to report?
   / TC29 in a pasture rehab. #26
You Tube has lots of videos about getting abandoned tractors running again. Check out the DieselCreek channel. He does this all the time and shows you the steps he goes through for a variety of engines. It's a rather methodical approach.
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
(11) 20' HEAVY DUTY INSULATED PANELS (A58376)
(11) 20' HEAVY...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A56858)
2016 Ram 4500 Crew...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX18L2YNA82156 (A57453)
2000 Ford F-150...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
