TC29 in a pasture rehab.
   / TC29 in a pasture rehab.
When I checked the oil, it is a bit milky not terribly milky but slightly, so I am going to do a oil change before I try anything else.
Changed the hydraulic fluid, and yeah didn't change since its not hydraulically driven (As far as I can tell)...so next is a trip to the tractor doctor...am sure it will be a clutch replacement. They quoted me $1,500 and that seems in line with other quotes that I have seen online from others...
   / TC29 in a pasture rehab. #23
Did you get the instrument panel going? I'm sure a new panel would be pretty costly?
   / TC29 in a pasture rehab. #24
Have you tried adjusting the clutch? What is the freeplay currently? The manual says about 1in at the pedal. You should also have a spring holding the pedal up.
   / TC29 in a pasture rehab. #25
Anything new to report?
   / TC29 in a pasture rehab. #26
You Tube has lots of videos about getting abandoned tractors running again. Check out the DieselCreek channel. He does this all the time and shows you the steps he goes through for a variety of engines. It's a rather methodical approach.
SEMI TRUCK FRONT BUMPER (A58376)
SEMI TRUCK FRONT...
49205 (A55788)
49205 (A55788)
John Deere 7000 8R Planter (A59814)
John Deere 7000 8R...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EF3FKE19870 (A57453)
2015 Ford F-150...
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
