TC25D parking brake
/ TC25D parking brake #1
deepsnow
bayview township, bayfield co. WI
NH TC25D
Had a little brain fart, backed out of the garage down the drive couple hundred feet with the parking brake engaged. Was in 4wd pushing some slush/wet snow with the 3pt blade. Seemed a little sluggish. Took a look at the dash. RPMs were fine brake light was on. Not absolutely sure but it seems my parking brake has less bite. Anyone know how steep a grade TC25Ds can be safely parked on? Anyone have any experience in adjusting the parking brake? Or have I worn enough brake "pad" that more than an adjustment will be necessary? Has anyone purchased a NH repair/maintenance manual? If so, what did you pay & was it worth the$$?
/ TC25D parking brake #2
Not sure how this measures up, but I have accidentially backed my nh 1920 off of my trailer with the p-brake engaged.... seemed a bit sluggish.. but pushed right through the brake. My brakes are new. I also have a little yanmar 1700 tractor and have backed it out of the barn with it's parking brake on.. same effect.
What this tells me is that tractors are very powerfull, and something as simple as a p-brake isn't going to hold up to the engine at regular engine speeds. Considdering a tractor is little more than a drivetrain with a seat electrical, and a hydropump.
Chris
/ TC25D parking brake #3
Brain farts are pretty common this time of year...
Doesn't the Operator's Manual that came with your machine tell ya how to adjust the parking brake?
My 670's book does...
/ TC25D parking brake #4
Noel, if you look under your tractor, you should see brake actuator rods going from the pedal to the brake actuator arms located near your rear axle. You adjust the brakes by loosening a locknut and adjusting the other nut that changes (shortens) the length of the actuator rod. Rotate one side about 1 turn and do the same on the other side (right side/left side). It's important to adjust both pedals so that the pedal depression matches when you have them locked together. When you finish adjustment, be sure to tighten the locknuts. This is the way it is on most tractors...I am not referring to a TC25 manual, but my TC45 is that way.
Are you sure you need to adjust the brakes? Can you engage the brake so the tractor won't move? I don't think one "B-F" should cause the brakes to wear that much. /w3tcompact/icons/hmm.gif
/ TC25D parking brake #5
I've done that with my TC45 -- to help keep the b-farts down I added a piece of brass tubing to the little rod that sticks up out of my deck that I need to kick off - so it's in the way and hard to forget./w3tcompact/icons/hmm.gif
mike
/ TC25D parking brake #6
You probably didn't wear enough pad off to matter, but it wouldn't hurt to readjust it like JimI said. Mine got to where they had a lot of play in the pedal at about 100 hours and I tightened them up so there's about 1/2" of play. The tractor has a lot of power, so it doesn’t surprise me that it can overpower the brakes.
I did a stupid thing with a Jeep I had once. I had it parked in about 3” of water and it froze overnight. When I went to drive it out, it wouldn’t move and I stalled the engine, so I put it in 4WD low range to improve the gearing and forced it out. I thought it was just stuck in the ice and forgot that I had the parking brake on. It bent the brake shoes and levers inside the drum and I had to replace everything!
jinman, thanks for the info. On flat terrain I think the parking brake holds the tractor. In neutral with loader bucket and rear blade down the tractor didn't move. Have to check out the parking brake function on a light grade next time out.
/ TC25D parking brake #8
Now that's using your head./w3tcompact/icons/clever.gif/w3tcompact/icons/grin.gif
/ TC25D parking brake #9
Doesn't pressing the brake pedal for any reason disengage the parking brake? When starting my TC 35 I put my foot on the brake (and the clutch) and this always disengages the parking brake. This must be a habit formed starting cars I guess...Glad to learn how to adjust the brakes though!!
/ TC25D parking brake #10
Noel, my description oif how to adjust your brakes was from memory and it turns out to be slightly incorrect. I mentioned loosening the locknut and then I said to adjust the nut which shortened the length of the actuator rod. Actually, all you have to do is to turn the actuator rod. The rod is threaded on each end and the clevis's on each end have a captive nut inside. This morning I read my repair manual for my tractor and realized I had given you slightly incorrect info. If you want me to download an illustration, I will, but my tractor might be slightly different from yours. I'm pretty sure it's the same principle though.
/ TC25D parking brake #11
I'm paying close attention to your problems - and plan on crawling under my 45 and taking a good long hard look - thanks for the heads up - it could very well save a lot of us from having the same mishaps. It sure does wear off the shine though don't it? /w3tcompact/icons/frown.gif 'Course my 45 vs. your 45D, doesn't have that particular part - but there are similar items that I feel could use an inspection now. I'd rather pay to have welds beefed up before they break rather than wait til I'm in the woods with it.
mike
/ TC25D parking brake #12
It's not funny, but over half the problems I've had have been with the "deluxe" features on my tractor. Some days I find myself wishing I'd gone with the gear drive tractor. Mostly though, I'm still really happy with the machine. ...and if it ever stops raining, I may even get it back together so I can use it. /w3tcompact/icons/laugh.gif
/ TC25D parking brake #13
Jinman, has New Holland offered you any form of compensation for the problems with your 45d? I would think that the factory should do something to make up for the problems you have encountered with your machine. It is one thing to have something unexpectedly fail but most of the problems seem to result from "penny pinching" by the bean counters. At the price we pay for these tractors we should not have these design problems. Just my opinion.
Bill C
/ TC25D parking brake #14
if it's raining - is the house weather tight so you can still work on it? I've worked enough airplanes in all kind of weather so I guess I don't mind working in the rain anymore ... I just suit up and go for it -- that way when it clears - the machine's ready. 'Course if the house is weather tight and your list is as long as mine - no sense in getting nutz - work the list where you stay dry. I've been away for weeks now - and my wife knows when I can't stand it any longer ---- it's time for the country, some seat time, and hardwork to relieve the stress. can't wait.
mike
/ TC25D parking brake #15
My house is still in the foundation stage, so it's no shelter in the rain. I also have a rule that goes, "I can do things when I'm wet and I can do things when I'm cold. But don't ask me to do things when I'm wet and cold." My body just shuts down./w3tcompact/icons/wink.gif It's a good excuse to be lazy.
Caterpillar D9 Dozer Parts and Service Manuals (A63117)
Caterpillar D9...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
Caterpillar 65-95E Tractor Service Manual (A63117)
Caterpillar 65-95E...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
