Backhoe TC25D & Backhoe
   / TC25D & Backhoe #11
bmac...I believe the backhoe subframe attaches the same way on all class II boomers. I think you can see in the attached picture that the front brackets hang down in such a way that you can't put a mmm on unless you unbolt the brackets (Spencer please correct me if I am wrong) and this is probably not something you want to do every time you want to mow. The technique that I have found works best for installing or removing the backhoe is to use the backhoe's hydraulics, specifically the stabalizers and the boom to lift it into place. When it is at the right height you can drive the tractor back so that the bh frame slides into the bracket under the rear axle and the holes in the front brackets line up such that you can slide the pins in. Its really pretty easy.
   / TC25D & Backhoe #12
There will be a Class 4 next fall TC47 and TC52
   / TC25D & Backhoe #13
Well we are told the mower deck and the backhoe brackets are compatible, but we have not put one with a backhoe so I could not tell you for sure until we try.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A57880)
2016 FORD F-550...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
Hose Reel (A55787)
Hose Reel (A55787)
