TC24D , losing power, seems to only be on side slopes?
   / TC24D , losing power, seems to only be on side slopes? #1
Thirim
New Glasgow, NS
2006 New Holland TC24D
Hey there, somewhat new to tractors and just signed up to this forum.
For any TC24D owners I have a question.
Tractor is having a problem when on angled terrain. Usually side slope but not limited to that. I've had trouble snowblowing up and down the driveway but always figured it was a little low on fuel for the angle.
I was out mowing the lawn and sidesloping when it happened again. I'm quick to catch it with the clutch so I don't stall, and this time it was everything the tractor had to get pointed uphill towards the garage. As soon as it did, it cleared itself and chugged merrily up the hill without a hitch. I'm not talking about some monster hill, it's at best 15deg and likely not over 10. This time I had 7/8 of a tank of fuel.
Tractor has about 400hrs on it.
Being Sunday, I'm screwed for parts until tomorrow but my first part to throw at it will be a fuel filter (and air filter since it's likely due but isn't bad at all)
It's definitely fuel related..
Anyone know how it picks up the fuel? My quick internet search shows it's some sort of siphon affair from the top of the tank? .. Could the pickup be messed up in the tank?
Looking for any advice before I dive into it.
Thanks.
   / TC24D , losing power, seems to only be on side slopes? #2
If I remember correctly, the hose is on the bottom of the tank. I think it is gravity fed, I accidentally pulled it off one time when I was changing the fuel filter housing. Make sure the gas cap is venting properly so that it isn't forming a vacuum and not letting the fuel out of the tank.
Thanks Jim, I had similar concerns with the venting. In the winter I thought it was iced up. I'll see what I can do to check it. I didn't think of it this time around.
   / TC24D , losing power, seems to only be on side slopes? #4
Sounds like there might be trash moving around in the bottom of the tank.
   / TC24D , losing power, seems to only be on side slopes? #5
Have you checked or changed the fuel filter?
bought a filter yesterday. That will be my first thing to try.
Is there only 1 filter?
   / TC24D , losing power, seems to only be on side slopes? #7
Yes. Only one fuel filter.
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF MISC CERAMIC TILE (A58374)
PALLET OF MISC...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
WHEELBARROW & TOOLS (A58374)
WHEELBARROW &...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
