TC24/26 vs B7610
   / TC24/26 vs B7610
</font><font color="blue" class="small">( fdny_hick:
If you work your tractor in rough terrain this could prove to be a liability. We at TBN are more than willing to share our experiences as well as help you spend your money /forums/images/graemlins/wink.gif Good luck with your research and pending purchase. /forums/images/graemlins/grin.gif Jay )</font>
Thanks Jay,
Its only money, right?
Mike
   / TC24/26 vs B7610
Thanks Jay,
Mike
   / TC24/26 vs B7610 #23
</font><font color="blue" class="small">( I'm not exactly sure what you mean. Can you explain the old style?
)</font>
I didn't know really how else how to explain so I called it that. /forums/images/graemlins/smile.gif But the "frame" of the tractor is actually the motor and transmission and then things are bolt to those. This setup just seemed to be a lot simpler and also a log stronger setup. Though I don't really know for sure if that is the case.
I saw that someone mentioned the 1/4" valving vs. the position control. When I was looking I had know idea what the difference was even when people explained it to me. But now that I've had position control I would have a hard time going to a tractor w/o it.
   / TC24/26 vs B7610 #24
)</font>
   / TC24/26 vs B7610 #25
Forgot to mention this earlier, but someone else mentioned the Supersteer option as available on the NH. Not on the Class 1 machines so that also removes that out of the equation. Also on the 3PH capacity and not needing the extra lift capacity. Any fence posts you would ever need to pull? The 3PH does a great job with that and but sometimes you might need all of the ooomph you can get. /forums/images/graemlins/cool.gif
   / TC24/26 vs B7610 #26
   / TC24/26 vs B7610
Hey Jim
I understand your old school frame now. I have a Yanmar buildt that way. I thought all small tractors were made that way. To tell you the truth I didn't know the Kubota Bs had frames. I'm then assuming that the motor/trans/axle assy doesn't have to be as heavy because its not supporting the weight?
Any 3ph control is better than whats on my 25yr old yanmar.
Strictly up or down, its a little tuff to find just the right height.
Mike
   / TC24/26 vs B7610
Hey Jim
Mike
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2001 HEIL PNEUMATIC CEMENT TRAILER (A51222)
2001 HEIL...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
