TC234DA PTO neutral safety switch
   / TC234DA PTO neutral safety switch #1
chickm1
The tractor will not start by the key, and has the PTO engaged light on the dash. Where is this switch located? What about a fuse?
   / TC234DA PTO neutral safety switch #2
Here is a thread about starting problems on the TC series. On the larger TC models fuse #2 blowing will give you the same problem.
TC33D wont start
   / TC234DA PTO neutral safety switch #3
My TC40DA was doing the same thing. Not starting then the PTO light would come on.
Does your starter click and the lights on the dash dim? If so add the abovementioned starter relay. Fixed mine straight up. Now it starts in seconds every time.
James
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2021 Polaris RZR 1000-4 (A52384)
2021 Polaris RZR...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
