TC234DA PTO neutral safety switch
   / TC234DA PTO neutral safety switch #1
chickm1
The tractor will not start by the key, and has the PTO engaged light on the dash. Where is this switch located? What about a fuse?
   / TC234DA PTO neutral safety switch #2
Here is a thread about starting problems on the TC series. On the larger TC models fuse #2 blowing will give you the same problem.
TC33D wont start
   / TC234DA PTO neutral safety switch #3
My TC40DA was doing the same thing. Not starting then the PTO light would come on.
Does your starter click and the lights on the dash dim? If so add the abovementioned starter relay. Fixed mine straight up. Now it starts in seconds every time.
James
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
