TC21d VS TC25d
/ TC21d VS TC25d
Thanks again to all of you!!!! I'm still considering the Tc21d with 600 hrs, but I didn't get a chance to go see it yet. The dealer was very informative, but he's about 35-40 miles away. As far as the place in VA, where is Fredricksburg at??? I travel to nothern VA sometimes. There maybe a chance I could get to the dealer. Thanks Again Guys!!!!!
/ TC21d VS TC25d #22
Steelfan: Check with the dealer on any service records they may have. If they were the original dealer or servicing dealer they may be able to give you some info. Also ask if they will do a service check on the PTO, and other hydro parts as part of the deal. What it means for them is they will get warranty work if it needs anything, and if it doesn't they get the unit sold.
/ TC21d VS TC25d #23
Remember, the diesel tractor engines are, basically, industrial engines. Would a diesel generator suffer undo harm after 600 hours? I don't think so... (unless all hours are at low(<1000 RPM)). These engines are designed to run at constant speeds for a long time. Low RPM's though, aren't good on any engine...one can pound the main bearings. However, diesel engines have heavier bearings then gasoline engines.
Since the farmer who had the machine used it for running equipment, there's little doubt he ran it at an efficient RPM.
Odd he had a loader on it, though.
/ TC21d VS TC25d
Thanks again to everyone , who replied. The warranty thing is a great idea. Is there a limit on Hrs when it comes to warranty work????? The deisel engine I'm sure is still in good shape. I still haven't got a chance to go see it. I' hoping to go this weekend. Thanks again
Kent
/ TC21d VS TC25d #26
Correct
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A67148)
2021 UTILITY VS2DX...
(4) TRANSPLANTER UNITS FOR PARTS (A64278)
(4) TRANSPLANTER...
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
Front Tank Bracket (A64126)
Front Tank Bracket...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2017 Volkswagon CC Sport Sedan (A64557)
2017 Volkswagon CC...
