Oil & Fuel TC18 Setup
   / TC18 Setup #1
BuzzyG
My TC18 has an inline fuel filter between the tank and the fuel valve.
I can't find that on any schematic, but I may not be looking in the right place. Is that normal??
   / TC18 Setup #2
I would say that isn't normal. I don't have one on my TC-24. I have just a hose that comes down from the fuel tank to the valve held at each end by clamps. I had to replace my valve a year or so ago because I broke the "ear" off and couldn't shut the fuel off to change the fuel filter. I ended up pulling the line off the fuel tank by accident. Man that sure made a mess :)
   / TC18 Setup
Thanks, Jim! I decided that it is an add-on, but I can't determine why someone would feel the need.
My valve is a current problem, in that it stuck closed a few days ago. I took it apart and got it to function until I can get a new one, but I can't imagine why it would stick like that.
I suppose I will leave the added filter there until I get around to changing out the hoses, etc. It really doesn't seem to be hurting anything.
   / TC18 Setup #4
An extra filter on a diesel won't hurt anything-until it plugs up. it probably somebody's "belt and suspenders' fix. My TD95D has a separate water separator and a fuel filter in the fuel delivery circuit.
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2001 Diamond 20' Fuel Trailer, VIN: 5FWFS18241R000024, Tandem Axle, Asset# 27 (A59076)
2001 Diamond 20'...
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
2022 FORD F-250 (A58214)
2022 FORD F-250...
1328 (A58374)
1328 (A58374)
2019 PETERBILT GARBAGE TRUCK (A58375)
2019 PETERBILT...
