TC18 quit charging
   / TC18 quit charging
Ok, didn't know that! I will check it again today with settings on ac and not dc. Thanks
Ok, I checked between the two wires at alt .and I get 24v ac low idle and 30v ac full throttle. So, looks to me like alt is good? So, now I will check the wires for continuity.
   / TC18 quit charging #23
Yes, I would say it passes the test of a minimum of 28v ac at full throttle. Checking wires and any connectors would be my next move.
FIXED IT!!!! Thanks everyone, Never would of thought the alt put out ac volts, and I found the problem, the wiring harness between the regulator, indicator light relay, and main harness was in bad shape and some of the wires were touching, I just made a new one with separate wires and individual terminals until I can find another harness, or find connectors to make my own. It's only about six inches long. Thanks again, you guys are great!!
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
