TC18 quit charging
   / TC18 quit charging
Ok, didn't know that! I will check it again today with settings on ac and not dc. Thanks
Ok, I checked between the two wires at alt .and I get 24v ac low idle and 30v ac full throttle. So, looks to me like alt is good? So, now I will check the wires for continuity.
   / TC18 quit charging #23
Yes, I would say it passes the test of a minimum of 28v ac at full throttle. Checking wires and any connectors would be my next move.
FIXED IT!!!! Thanks everyone, Never would of thought the alt put out ac volts, and I found the problem, the wiring harness between the regulator, indicator light relay, and main harness was in bad shape and some of the wires were touching, I just made a new one with separate wires and individual terminals until I can find another harness, or find connectors to make my own. It's only about six inches long. Thanks again, you guys are great!!
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2014 Jeep Grand Cherokee (A56859)
2014 Jeep Grand...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
