TC18 quit charging
   / TC18 quit charging #1
MacFacts
Killeen
2002 TC18
Hello, just joined this forum and was hoping someone could help me with my charging problem on my TC 18. Checked all fuses and they are good, took alternator off and had it checked and was told it was good, bought a new voltage reg. And installed it, but still not charging, I can charge battery and it will last several days before I have to manually recharge it? I would appreciate any ideas. Also, I did noticed the old voltage reg it looked like it had got real hot, it had some melted plastic coming out of it. Would appreciate any ideas I could try. Thanks
   / TC18 quit charging #2
I would check the voltage at the battery terminals with a voltmeter when the tractor is off, then with the tractor running. If the voltage is the same, I would suspect the wiring from the alternator to the battery some where. A fully charged battery will likely read somewhere around 12.6 volts. If it is getting a charge when the tractor is running, it should be higher, 13 or maybe even up to 14 volts. Years ago I had to replace the voltage regulator on my TC18, and that fixed the problem. Then earlier this year, the battery light came on again. This time it was a connector that was disintegrating on the wiring harness that connected to the alternator terminals. I replaced that with some Anderson connectors and all was well again.
   / TC18 quit charging #3
Do you have a volt meter and know how to use one?
Yes, I was a auto mechanic for 10 years, and a electrician for 25 years, and very mechanically inclined.
   / TC18 quit charging #6
I'd inspect the cables. They've been known to break down internally while the insulation still looks fine.
   / TC18 quit charging #7
So whats the voltage at the battery, running and not running.
The FIRST reply to your post asked this question...
T
Battery voltage is about 12.4v sitting off, no change when running. I did noticed the plastic on my connector to the alternator was disintegrating also, I will replace that and see what happens. Thanks
Battery voltage is about 12.4v engine off, no change when running. I did noticed the plastic on my connector to the alternator was disintegrating also, I will replace that and see what happens. Thanks
   / TC18 quit charging #10
Ok, not getting juice back to battery.
Whats the voltage at the alternator output?
3-wire alt or single?
IF 3 wire, getting juice to the field?
For an auto mechanic of 10 years and electrician for 25, I would have though you would have checked these things already. Maybe you did and just arent giving us the details for some reason?
Either way, No chance anyone here is going to be able to help you if you dont give us some details.
You have a meter...use it. Check out the alternator. IF it has power to the field, and is spinning, it should be making a a few volts more than the 12.4. If not, change it. Pretty simple to diag. a basic charging circuit if you have a meter
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
Genie GTH-644 (A50490)
