golferdrone
I have a TC33. I have tried to read the post before posting but I am not having any luck to get it to start.
Key first click-glow plug, it sounds like a relay clicks and that is all i get. I hired someone that fixes lawnmowers they looked at it, we moved levers around to no luck. Wiggled the battery cables and started, then would not start, wiggled cables again, finally started. Moved it outside of my barn, and then was going to use their recommendation, cut the old positive end off the cable at the battery, replace, and tractor should work great. Installed new brass clamp on battery cable attached to the battery. Turned key and glow plug, dash lights, headlights all will work, turn key to start position and nothing.
*New Battery
*Loosened negative battery cable and reattached to make sure no loose fittings.
*someone that I hired that fixes mowers discovered my positive battery cable was loose and thought the battery end connection was bad, replaced just the end. Did not help
*interchanged all relays that are same kind, did not help
*checked all fuses on right engine firewall, checked fuse at starter.
*swapped all relays to no luck under right side dash
*PTO light is not on
*Have tried upper and lower neutral lever
I have very limited tractor knowledge.
I use to need to wiggle the gear selector to find "neutral".
My pto light is not on, and my 2 sets of little plugs underneath driver side are connected
I have no idea how to check the neutral safety switch or where it is located on tractor.
I see people talking about jumping the starter, I only see 1 cable attached to the starter. The big red cable going to the battery. Other cables attached to the battery cable look to be attached to alternator
*New Battery
